First of all, I use PCI-6229 M-Series card and LabVIEW 8.0.
I am trying to develop a general purpose program consisting of three parts each of which is inside an independent while-loop. Part-1 is for continuous data input through the DAQmx Read, part-2 for analyzing the data passed by part-1, and part-3 is for continuously generating the results from part-2 through the DAQmx Write. I used FIFO queue to manage seamless data passing among the 3 parts. I also used "Rendezvous" to synchronize the starting timing for them. However, I found all of the output signals have a constant delay of about 140ms (pretty long) relative to the timing of input signals from DAQmx Read.
In order to clarify how my program works, I attached you a simple VI consisting of the 3 parts I've described above. This VI was designed to simultaneously using DAQmx Write to generate a copy of the signals from DAQmx Read. I connected the analog input channel to a microphone for sound input directed into DAQmx Read. And I used an oscilloscope to monitor the sound signals and the simultaneously generated copy of signals by DAQmx Write. Even in such a simple case, I also observed the generated signals having a constant delay of ~140 ms relative to the sound signals. Regardless of such latency, these two sets of signals are just identical. I tried to feed external timing signals to a PFI channel shared by DAQmx Read and Write as the sampling clock, but still get the same latency.
I have referenced NI's knowledge base, tried hundred of tests, and posted my problem on the borad of "Multifunction DAQ", but still got no help. Is that just a limitation of LabVIEW for such type of task without using its Real-Time module? Or do I just miss any key points? I appreciate any of your help or comments and if I didn't clearly state my question, please let me know. Thanks.
Claude.
