Big problem with BridgeVIEW -- Applicom -- S7-315-2DP
I have a big problem with tag's refresh time. My application have:
- S7-315-2DP.
- Applicom card for profibus DP communication.
- BridgeVIEW 2.1.1.
My refresh time is nearly 4 seconds, and when I launch BVEngine, I must wait nearly 5 minutes for launch my application.
(3,035 Views)
This is by no means typical behavior. I'm curious as to the details of your setup. Can you provide the information below:
- Computer type / speed (ie. Pentium III/866)
- Operating System
- Number of tags in the BridgeVIEW VI, and the poll rate setting on those tags.
Also, I would be interested to know if the same slow BV engine launch and refresh time occurs with a small VI/SCF file that is only reading or writing one tag. This would narrow down the problem to either the base BridgeVIEW/Applicom installation, or the VI that is being run.
Greg Caesar
National Instruments, Applications Engineer
(3,035 Views)
Thanks you, for your time.
Computer description system:
- PIII 800 MHz, 128 Mb, 10 G HD, graphic card of 8 Mb.
- Windows NT 4.0 SP 6.
- 580 tags, but I must refresh 30 tags (analog and digital)only, and the other tags are used for PLC configuration. But they must be declared.
When I define 16 digital tags my refresh time is nearly 1 second. These tags are defined in the same DB.
If you need the SCF file, I will send you.
Jorge.
(3,035 Views)
