Binary Array
How do I create a 1 dimensional Binary array
(4,829 Views)
how do I create a one dimensional array but in binary format....
attached file has a better discription to what Iam saying..
THanks
(4,828 Views)
Duplicate Post.
I was going to try to help answer your question in this thread until I saw you already asked the same question and had already received help in the other thread.  Why did you create a new thread?
All that does is waste people's time.Smiley Mad
Why do you keep doing that?  I see you've already been told about this in other threads. http://forums.ni.com/t5/LabVIEW/Stepper-Motor-VI/m-p/1687544#M599354
(4,824 Views)
Your question does not make any sense.  Any number stored in a computer is already in binary format.  You can change the appearance of a numeric control or indicator so that it will show the number in binary instead of decimal; to do that, click on the numeric control (it must be an integer, not floating point), go to Visible Items -> Radix, and then you can click on the radix and change the format to binary.
(4,819 Views)
