Binary Conversion...
Hi All,
Ok this is quite a hard scenario to explain so I hope I make sense...
Basically I want to convert a number to binary but each bits value is multiplied by something I specifiy.
For example:
Say I have the number 63,500 and want each bit multiplied by 500, I want the binary for this to be:
1 1 1 1 1 1 1
Where the sum of these added up would be 127 then multiplied by my value of 500 = 63,500.
Can anyone think of a quick way of doing this?
(3,504 Views)
Just divide your integer by 500 (I assume your number is a multiple of 500, so use quotient and remainder for the division) and display it in binary format. 🙂
(3,500 Views)
Hi thanks for your reply,
That method does work perfectly.
Another method I tried out succesfully was using the format to string and specifying % myNum b - where myNum is the amount of bits you want shown. I took my original number and divided it by 500 and use that method.
Just thought I would let everyone know that your way and mine works 🙂
(3,467 Views)
