Binary String and Binary Number to Decimal Number Conversion
Hi everyone,
Would you please tell me how to convert this kind of string data (that is from spectrum analyzer) to numbers?  the picture is attached.
Many Thanks,
Marjan
Message 1 of 10
(4,960 Views)
Hi Marjan,
Simple answer: read the manual of your SpectrumAnalyzer to know how to convert that string…
You're kidding: you want help on string conversion with your VI - and all you attach is an image of its frontpanel?
It's like bringing a photo of your car to the repairshop when you want help with it…
Message 2 of 10
(4,952 Views)
Hi GerdW,
Thanks for your reply.
In the user manual doesn't say anything for converting in the Labview!!
I just  wanted somebody tell me how to convert this kind of data and I thought no need to send the real data. If you think is better to have it as vi, here is attached.
Marjan
Message 3 of 10
(4,937 Views)
Hi Samamiri,
I don't expect that.
But I expect a clear description of how the data is encoded in this string. And you need to know that encoding to be able to decode the string!
You still wasn't able to name the exact type of your analyzer. You didn't tell us how you received that string (using which command and parameters)!
And the VI you attached is empty as you forgot to set some meaningful data as default value…
Message 4 of 10
(4,931 Views)
OK, Thanks, I will find out how the data is encoded and then back to you.
Message 5 of 10
(4,926 Views)
I used a simple read and write vi which is attached, the Spectrum analyzer is Hantek, and there are two formats for output data:
ASCII : The data point is ASCII character, separated by comma.
REAL: The data point is 32 bit binary number.
Marjan
Message 6 of 10
(4,918 Views)
Accepted by topic author Samamiri
Strip off the first 11 ASCII characters.  Typecast the remaining to Single Floating Point
Message 7 of 10
(4,902 Views)
Thank you very much for your suggestion. It seems it  work but when I plot the data it is slightly different from that one which shows by the spectrometer unit. You can see both the vi with the graph and the screen shot of the spectrum in the attachments. And also this result comes by real format and when I change it to the ASCII format that completely gives a different result.
Thanks again
Message 8 of 10
(4,893 Views)
Attached another file
Message 9 of 10
(4,892 Views)
Now it works perfectly and the graphs are matched, just I have changed some scales. Thanks for your help.
Message 10 of 10
(4,876 Views)
