Binary to Voltage Conversion of encoder data on cRio 9073 using FPGA
I am using FPGA with a cRio 9073 to acquire torque and absolute quadrature encoder values. It says in the FPGA instructions that the documentation for the 9073 should include the binary to voltage conversion, but when I looked at the documentation, it wasn't there. Where can I find the conversion value or function to convert binary encoder data back to voltage? The encoder is hooked up to an analog converter and is acquired with a 9215 AI (+-10V differential). Thanks
(2,820 Views)
There are individual formulas for one or a group of modules.
LabView examples path:
LabVIEW 2010\examples\CompactRIO\Basic IO\Analog Raw Host Calibration\AI Raw Host Calibration
LabView help topic
Converting and Calibrating CompactRIO Analog Input Values (FPGA Interface)
Best regards
Christian
(2,805 Views)
Thanks a lot. I ended up going into the FPGA target program and pulling out the conversion values. Data looks good and I am happy.
(2,739 Views)
