Binding a shared variable to a NI-PSP data object does not work
I want to share data between a RT-target and one or more hosts (LV 8.6.1). The network shared variables are deployed to the RT-Target.  According to NI accessing shared variables from another project or host has to be done by defining a shared variable on the host and aliasing it to the NI-PSP data object on the target.
 I did that and the host shared variable generated an error (0x8BBB0011) during runtime.
Next I aliased to a shared variable deployed on the host from another project. This did work.
Another thing I tried was to bind the variable from the RT-target to a display element:
This is working !!! And as you can see the path of the NI-PSP data object is exactly the same ! So what is the difference between binding a data object to a shared variable and to a display element?
Is there a bug in the SVE or am I missing something here?
The host project:
The publisher VI
Hope, someone has an answer.
Regards
Matthias Quade
(4,403 Views)
Accepted by topic author mq17
Dear Mr. Quade,
thank you for posting at the National Instruments Forum. There is a known issue with the path of the bound variable with LabVIEW 8.6.1
Please download the patch for LabVIEW 8.6.1, it should solve your problem:
http://joule.ni.com/nidu/cds/view/p/id/1255/lang/de
Best regards from Munich
Marian Vorderer
(4,372 Views)
That was in fact helpful.
Thank You for your support.
Regards
Matthias Quade
(4,367 Views)
