Binning or averaging XY data
Im using a USB-6009 to measure two voltages continuously at 22 kHz. The data is given to Labview by the DAQ in pieces of 1000 samples which constituate the X and Y data of an array (they are actually the probe voltage and current of a Langmuir probe). I wish to do some averaging to cancel out some of the noise, for instance, by binning the 1000 point data set to 100 points using 10-point mean averaging. How would I go about doing this? As far as I can see, the built in averaging routines of Labview only work on waveforms (X- and Y- versus time respectively), and cannot be applied on a (time independent) XY set.
Casper
(6,702 Views)
Hey Casper,
      Do the 1000 samples represent 500 X/Y pairs?  How are the Voltage/Current values embedded in the data, and which (voltage or current) is on the X-axis of your chart?  In this situation, will the bins have to be different "widths" in order to keep the same number of points in each [vertical] bin?
Casper
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(6,677 Views)
Hey tdb,
Im reading two voltage channels via the DAQ assistant (the conversion to current is done later, but the current is the Y-axis) of 1000 samples each - each of those (X,Y) pairs being correlated. Both are in the range -10 to 10 V. Its not important for the bins to be the same size. What ever is easiest. What I want to do is to bin the X-axis down to, say, 100 data points to get rid of some of the noise present in the Y-axis (thus, each "bin" would represent the weighted average of ~10 (X,Y) pairs). I imagine somethin along the line of creating equally sized bins on the X-axis and setting the Y-axis value of the bin Bn to a weighted average of the Y-values that fall into Bn. Im not sure its correct of me to use the term "binning" in this context, but I hope you can see what I'm looking for.
Thanks for you reply,
Casper
(6,653 Views)
Up to here, I'm thinking we could calculate & plot the "centroid" of every 10 consecutive X values (once sorted on X).
... not that I really know how to calculate a centroid! Smiley Wink
If you mean each bin might span the same range of current, what guarantee is there that any data-points will fall (or have fallen) into a particular current-range?
Cheers!
Message Edited by tbd on 04-27-2007 12:07 AM
(6,644 Views)
Hey Casper,
      In case you can (still) use it, I went ahead and implemented the "Centroid" binning described earlier.
Cheers!
(6,607 Views)
Hi tdb,
I had a chance to look at the VI you sent me... it does the job for me. Thanks a lot for you help!!
Casper
(6,573 Views)
