Bit error rate of a channel
Hello.
My question is I have a channel and I want to measure the data transmission performance for data rate upto 100Mbps. How do I send a signal via the channel amd retrieve back at the end of the channel and calculate Bit Error Rate. I wanted to do it using NI mydaq..
Please Help..
(5,326 Views)
First, you'll need hardware that can generate that high of a rate. As you can see from the specs, the MyDAQ cannot come close. For reference, see:
https://forums.ni.com/t5/Example-Code/Bit-Error-Rate-Testing-BERT-Reference-Example/ta-p/3996019
(5,307 Views)
Thank you..But is there a way of calculating BER for low data rate such as in Kbps using the mydaq??
(5,296 Views)
Not if you want to generate/read a signal with the digital I/O. You might be able to achieve 1Kbps but since the digital is software timed, you'll have quite a bit of jitter. What sort of channel are you trying to test?
(5,290 Views)
I have designed a coupling circuit to be tested over power line.. I want to calculate the BER of the data transmission between transmitting coupling circuit and receiving coupling circuit placed at different nodes in a building.
(5,276 Views)
And what sort of physical signal do you wish to send? As I said, using the digital lines would probably not work.
(5,269 Views)
For a first time, i would prefer to send baseband signals as a sequence of pulses: 101010111 etc and check for BER..Later I am planning to use modulation and line coding and transmit the same data.
(5,254 Views)
