Bitwise shift operation?
int16 x = 0x0;
int16 y = 0x0;
for (int8 i = 0; i < 16; i++)
    result1 = 0x1 << i;
    result2 = 0xff00 >> 8;
Any idea?
Thank you in advance.
(20,790 Views)
Numeric Palette >> Data Manipulation  >>>> Logical Shift.
Or search the palette for "shift".
Message Edited by Ravens Fan on 07-15-2009 05:23 PM
(20,789 Views)
Thanks for the quick info, but I am not sure I understood the details on logical shift correctly.
According to description, it says "If y is less than 0, the function shifts x right y bits" and
this conflicts with my example, so how do you shift right if Y value is not less than 0?
Could you show me the labview example for my case?
(20,783 Views)
Accepted by topic author horanyee
horanyee wrote:
... so how do you shift right if Y value is not less than 0?
multiply y by -1 first. There is a primitive in the numeric palette called negate.
(20,777 Views)
Read the whole description.
"If y is greater than 0, the function shifts x left y bits (from least significant to most significant bit) and inserts zeros in the low-order bits. If y is less than 0, the function shifts x right y bits in the positive direction (from most significant to least significant bit) and inserts zeros in the high-order bits. "
If Y is positive, the shift is to the left y bits.  If Y is negative, the shift is to the right y bits.
Message Edited by Ravens Fan on 07-15-2009 05:44 PM
(20,768 Views)
I was think too hardSmiley Very Happy
Thank you.
(20,763 Views)
