Blank Explorer Folder and Files
Hello All,
Please does anyone know why this happens?
BlankExplorer
Best.
(3,111 Views)
Is it reproducible on a different machine?
Also provide more information: LabVIEW version, toolkits, OS, bitness, etc.
Can you attach a small VI that demonstrates the problem?
(3,105 Views)
No its not reproducible even on the same machine. It's quite random.
Labview 2012, ALL tool kits (Academic Site) Windows 7 Pro. 32 bit Labviews on 64 Bit Machine.
I can reproduce this problem wven with a small file selector its seems fine.
Thanks!
(3,066 Views)
Hi Sam
Thank you for posting.
As altenbach asked, could you please attach a small VI which demonstrates the problem?
You stated that 'it's quite random', so does this only occur sometimes? It seems like the order of elements in the window is jumbled, if you drag the bottom right corner to enlargen it does the file selection tree become visible?
Have you been able to reproduce this using a file selector in another application? (i.e. notepad)
File open dialog boxes are usually a system component(i.e. this could be an OS issue) called via API.
Kind Regards
Chris
Chris | Applications Engineer NIUK
(3,048 Views)
I also suspect its a system component called via API but the question is which is it. Thats it the hard part to trace. Labview works fine with a simple file selector VI.
(3,001 Views)
