Blank bar across top of screen
With the advent of LabVIEW 2013, my applications have a blank bar across the screen, above the menu bar, when they are executed.  I have not found a way to get rid of this bar.
Message 1 of 26
(7,164 Views)
Post a screenshot of this so we can see what it looks like.
What version of Windows are you using?
Could it be a problem with the video drivers?
Message 2 of 26
(7,154 Views)
Can you send an image of this? What OS are you running under?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 26
(7,153 Views)
lol, seconds slower!
Putnam
LabVIEW Champion
Message 4 of 26
(7,151 Views)
Attached is a screen shot showing the blank white bar across the top of the application.  If I minimize the application and restore, the bar comjes back as black instead of white.
I am using Windows 7 on my laptop.  The target systems are WindowsXP SP3.
LabVIEW 2013 shows this problem.  Not happening in LabVIEW 2012 SP1.
Happens in Development environment and in the built EXE.
Message 5 of 26
(7,140 Views)
What happens if you get rid of the Windows Aero theme?
Message 6 of 26
(7,117 Views)
A.  I don't know how to get rid of the Aero (and don't want to on my laptop)
B.  This shows on the built EXE in winXP without Aero.
Message 7 of 26
(7,109 Views)
I changed to the Windows 7 Basic theme and get the same bar.
I changed to the Windows Classic theme and get blank bars on the right side and bottom, but not on top.
The bar on top is like the LabVIEW toolbar has been removed but left the blank space.
The rights side and bottom bars in Classic are like the vertical and horizontal scrollbars have been removed leaving blank spaces.
Message 8 of 26
(7,104 Views)
I would check the setting that talks about the level of hardware acceleration used by your video card.
Message 9 of 26
(7,101 Views)
This is still an issue.
I have attached a sample vi.
If you place a decoration  like a raised panel and right click the vi icon and size the vi window to the same size as the raised panel, then you can see this problem when you run the vi.  There are blank bars where the tool bar, vertical scroll bar and horizontal scroll bar used to be.
Message 10 of 26
(7,009 Views)
