Blank or missing icons in function / control palette.
Hi, I just started using LabVIEW community version 2025. Yesterday I created a project and everything was working fine, I was able to write some code to control a motor and read value from a load cell. Today I reopened the project to continue working but the function palette is blank, no icons or whatever. When I dragged the empty window to enlarge it, it results in a graphical glitch. The code is still working, I can hit run and read date from sensors, I can still control my motor, but I can't open the palette to create a new function. You can see what I meant in the attached screenshots.
Should I try repairing or uninstalling LabVIEW? please help me, thank you.
(781 Views)
Repairing all modules doesn't work either. I will attempt reinstalling.
(745 Views)
Reinstalling the software doesn't fix it. I don't know what to do now.
(737 Views)
Anyway, I found the solution! You have to go to tools -> advanced -> Edit Palette Set.. -> Restore the default and that's it! Even though I changed nothing beforehand...
(726 Views)
That's very strange.  I'm glad you fixed it, but I've never seen that happen.  I've messed up my palettes pretty bad in the past trying to add/modify them, but all I got were a few palettes showing a question mark.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(717 Views)
Slick move - seriously.  If all else fails, reset to defaults.
Bill
CLD
(Mid-Level minion.)
(689 Views)
