Blink DAQmx LED for Identification
"I don't Think" an extra software reset here or there should cause anything odd.  At worst the device should be reset.
Now, that doesn't mean that there could not be a timing issue with multiple resets being "Debounced" into a single reset but you would want to re-reset at a rate observable by a Mark 1 Mod 0 eyeball anyway.
Message 11 of 15
(2,543 Views)
Message 12 of 15
(2,531 Views)
I did just look back through the whole thread
You mentioned the user is to select a device from the list of devices attached to a computer.
You do know about the filtering options on DAQmx FP Objects right?  (Right-Click Filter options)  Setting those may help you too.
Message 13 of 15
(2,520 Views)
Funny you should reply to this topic. (What is that eight ball telling you? Smiley Happy)
I did a little more digging and need to test with other DAQmx devices.
  1. The reset device does blink the active light, but in the case of a cDAQ device in a chassis you have to reset the chassis not the device.
  2. Doing something like the snippet below will cause the active device light to stay on for one second.
For now #2 may work, I need to talk to the tech using the device and see if they are okay with that solution.
As far as the filtering goes, for this case I don't think it's applicable. I have a table that is populated by all the attached DAQmx Devices attached to the computer. (See below)
The user double clicks the device they want. The problem was when we have mutliple devices that are the same model attached. Which one is the user is the clicking?
Another tidbit: I use the snippet above without the wait to see if a device is in use. If I get an error somebody is using it.
Is there a better way?
thanks again for your help.
regards,
mcduff
Message 14 of 15
(2,515 Views)
regards,
mcduffT
Answer unclear Ask again!
Message 15 of 15
(2,509 Views)
