Blink LED using property node
How do you use property node to make an led blink?
Message 1 of 10
(19,434 Views)
Right click on the boolean in the block diagram, select create - property node. Move mouse to newly created property node and use the hand tool (pointing finger), left click and choose Blinking. Right click on the Blinking property node and choose Change All to Write or Change to Write. Wire a boolean True constant into the property node. This will cause the LED to blink. Wiring a False into the property node will stop the blinking.
- tbob
Inventor of the WORM Global
Message 2 of 10
(19,427 Views)
tbob is right but take note that blinking is very different than cycling between true and false states. The blink color will be different as well.
Message 3 of 10
(19,424 Views)
what if i wire a False value and it does not stop!?!?!?!?!
I want it to blink while no one presses START and stop Blinking when the user press START.
What i am doing wrong?
Message 4 of 10
(18,820 Views)
Hi ,
I think you must see this VI.. let me know if it helps..
Nitz..
(Kudos are always welcome;))
Message 5 of 10
(18,800 Views)
First u have to wire true to the blink property node to make it start blinking, just before u start the 1st while loop.
Also what is the mechanical action of ur start button?
Use false constant to stop LED blinking
Message 6 of 10
(18,787 Views)
Message 7 of 10
(18,787 Views)
Plz find attached VI for ur help.
Message 8 of 10
(18,776 Views)
It is really helpfull but i want my buttons to have a latch action.
Is there a way to work it out?
Message 9 of 10
(18,761 Views)
In the Blink.vi example provided by Kekin, the start and stop buttons are latched type.  The Boolean LED is an indicator and it does not have any mechanical action.  Latch action can only be applied to controls, not to indicators.
- tbob
Message 10 of 10
(18,752 Views)
