Blinkig property of boolean custom control
I would like to create a custom boolean control (I need a control which looks like modern square LED but in shape of a frame) and preserve blinking property. How to do this trick? Do in need to unlock some hidden feature like "enableSecretPopups=True" in ini file?
All my attempts end up with barely visible blinking in a form of some kind of "shadow"...
Thanks in advance 🙂
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,987 Views)
Only some parts of the control blink, so you should make sure to resize the correct parts when in the control editor. can you attach your example control?
(2,967 Views)
I used some random frames from Google, for now. See the attachment.
Michał Bieńkowski
CLA, CTA, CPI
(2,895 Views)
