Blinking Boolean Text is on every tab - why?
Hi
I build a vi with a tab. On one of the tabs should blink a "Text Button". But when the Button is blinking the "Boolean Text" is seen on every tab, although the Button is only on one tab.
Like always: an example tells more than 1000 words, see attached vi
How can I solve this problem?
Thank you in advance!
  XS-er
Message 1 of 8
(3,890 Views)
Hi XS-er
I just ran your vi - without any strange behaviour.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 8
(3,881 Views)
The same happens when I run the VI, it also occured when I recreated it...
Message 3 of 8
(3,873 Views)
Hi Thomas,
Did you test that in LV 8.0?
It behaves as reported by XS-er when I run it in LV 7.1.
I recall this as being a bug (not sure which version) but if you tested in in LV 8.X then the bug has been fixed.
Ben
Message 4 of 8
(3,874 Views)
Ben
Obviously it must be a bug. I ran it under LV 8.0 without any problem.
So - you guys definitely have to upgrade ;).
Using LV8.0
Message 5 of 8
(3,871 Views)
Becktho wrote;
So - you guys definitely have to upgrade .
I prefer to deal with the enemy I know than the enemy I don't know.
I am not to the first to be of this opinion. When Saul offered David his sword, shield and armor, he shunned them and decided to confront Goliath with just a sling and his faith.
My "sling" may be a little ragged, but I have slayed many a beast with it.
Ben
Waiting on LV 8.0.2
Message 6 of 8
(3,865 Views)
XS-er wrote:
... How can I solve this problem? ...
Other than upgrading to v8.x, the workaround frequently used is to enable blinking for the boolean only when the page containing it is the active tab page.
In LV6.0.x, everything that blinked showed through tabs. That was fixed in LV6.1 ... except for booleans with text which obviously took a bit longer.
Fading out. " ... J. Arthur Rank on gong."
Message 7 of 8
(3,840 Views)
Thanks to everbody for the extreme fast answers!!!
I simply installed LabView8 und the problem was solved.
Message 8 of 8
(3,822 Views)
