Blinking LED even without a property node
So I wanted to try this Blinking LED. Used the property node to get it blinking. Din't like it so removed the property node. Yet, the LED still functions with blinks. Attached is a GIF that shows it in action.
How so? The code is not super fancy but here it is
NI System Configuration:
- NI PXIe-1071, 4-Slot 3U PXI Express Chassis , 1 GB/Slot throughput, Part Number: 781368-01
- NI PXIe-PCIe8381,x8 Gen2 MXI-Express for PXI Express Interface,3m, Part Number: 782522-01
- PXIe-5160 PXI Oscilloscope, 500 MHz, 10 bits, 2.5 GS/s, 2 Channels, 64 MB, Part Number: 782621-01
- Astronics PXIe-1209 2-Channel, 100 MHz PXI Pulse Generator, Part Number: 785033-01
(3,019 Views)
Accepted by topic author asukumari
You need to reset the property node, to false for blinking. Even when you deleted the property node, it did not remove the blinking property from the indicator.
mcduff
(3,011 Views)
