03-07-2008 07:59 AM - edited 03-07-2008 08:00 AM
03-07-2008 08:05 AM
You have not given us enough info to be of much use.
Standard follow-up question is "Can you post a stripped down example that demonstrates this?"
BUt lacking information I will guess. ![]()
Spectrum Analysis usually invlove large data sets. So how much data is being plotted how often?
Sometimes "defer FP updates" followed by "hide graph" then "apply new data", "unhide graph" then "Undefer FP updates" can help.
What type of graph are you using?
What are the spec of the machine?
What version of LV?
Still tring to help,
Ben
03-07-2008 08:11 AM - edited 03-07-2008 08:20 AM
Man your fast... I was switching machines so I can post my code and give you specs. Coming back to edit it. I've attached my code. The VI you need to run is "Front Planel.vi"
I'm running this on a sever 3.25 gb of ram. Quad cpu running at 3 ghz. Over 1.5 TB of harddrive space. I'm using a NI board PCI 4462. LV latest stable 8.5. Nothing else running in background.
It's basically 4 graphs. 1 SFTF spectrogram. 1 continuous updating waterfall. 1 Power average just a chart. 1 general XY. I have 2 outputs. One is just the raw data. The other is the XY chart.
I'm trying to run this with out write, but it's going to take several hours to see if it will do it again.
Message Edited by d1sturbanc3 on 03-07-2008 08:13 AM
Message Edited by d1sturbanc3 on 03-07-2008 08:15 AM
Message Edited by d1sturbanc3 on 03-07-2008 08:16 AM
03-07-2008 08:23 AM
03-17-2008 01:06 AM
03-17-2008 08:12 AM
03-17-2008 08:18 AM
