Blinking indicator
Hi, how I can make an indicator that change the color if the event occur and after that event the indicator come back to the previuos color? And then again then the event occur it will changes?
Message 1 of 12
(6,256 Views)
For example when peak is more than 2 the indicator blink one time and back to the previuos colour.
Message 2 of 12
(6,254 Views)
Hi onoff,
either use the Blinking property or set colors using color properties...
Message 3 of 12
(6,244 Views)
I know that. But how to do that the blink just continuos for short time "just blink"
Message 4 of 12
(6,230 Views)
I want to do like on (when signal peak is more tjan 2) and off.
Message 5 of 12
(6,218 Views)
You need to have The Open G toolkit to make this work. Use VI Package manager to load the toolkit.
Glad to answer questions. Thanks for any KUDOS or marked solutions 😉
Message 6 of 12
(6,197 Views)
I can not open, your version is newer.
Message 7 of 12
(6,188 Views)
Booleans can have a "value" which is True or False. They also have a "colors" property so you can change what the False and True colors actually are. If you only want 2 different colors, you will probably just want to change the value.
How you implement the timing is up to you. You can set the value to True, add a "Wait (ms)" VI with a value of something like 750ms, and then set the value to False.
Message 8 of 12
(6,185 Views)
Where I gave to put this "Wait (ms)" VI?
Message 9 of 12
(6,176 Views)
Message 10 of 12
(6,173 Views)
