Blinking string color
By default, a string indicator blinks in red when it is set to blink in the property node. i would like to know if is it possible to change this color??
thanks!!
(5,224 Views)
Accepted by topic author rlages
thanks!!
You can't, but here's an article about how you can fake it if you really, really need something like that.
Bill
CLD
(Mid-Level minion.)
(5,213 Views)
Actually, you can change this, but the change is global. The details are at the bottom of the article billko linked to.
Note that this is set in the INI file, so if you're building an EXE you will have to find the relevant line in the LabVIEW.ini file and put it in your EXEs INI file.
___________________
Try to take over the world!
(5,166 Views)
IN LV 2017 go to options>category Environment>Color, change blink fore & background colors.
this will change the colors for all items that are set to blink, I don't know how change the colors for individual items.
R
(3,407 Views)
