Block Diagram Error
I'm getting an error when i try to connect two sub-vi's.
Error:
The type of the source is 1-D array of double.
The type of the sink is 1-D array of waveform.
Does someone know.
I'm using LV6i.
Iwert
(3,054 Views)
Yeah. You've gotten the error because you've tried to wire an array of
doubles to a waveform array 🙂
Type "waveform" is a new datatype introduced in LV6 that's essentially a
cluster of the DBL data array and timing information. The resizable function
"Build Waveform" under the "Waveform" palette allows you to combine your 1-D
array of doubles with t0 and dt values to get a waveform that can be fed
into the waveform terminal.
Iwert Mijnders wrote in message
news:<3A223E5F.6824A2BA@hotmail.com>...
> Error:
> Does someone know.
> I'm using LV6i.
> Iwert
(3,054 Views)
