Block Diagram Errors....Tunnel: missing assignment to tunnel
Hitting the cleanup block diagram button would have helped you also.
Message 11 of 18
(1,275 Views)
@HowardAsh wrote:
Not everyone is perfect.  Sometimes when you remove all broken wires, one finds that an important one was deleted by mistake.  Good software design makes it easy to debug.
Again, if you click Show Error on Error List Window (or double click the error), it will bring you right to where the error is and highlight the structure responsible (in this case, the open tunnel). Not sure how NI could have possibly made it easier than that.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 12 of 18
(1,269 Views)
Yes, this is the easiest way to do it.
Bill
CLD
(Mid-Level minion.)
Message 13 of 18
(1,258 Views)
@billko wrote:
Click on the broken run arrow.  It will list all your sins in a dialog box.
Or Ctrl-L
Message 14 of 18
(1,221 Views)
That's why Ctrl-B scares me.
Message 15 of 18
(1,221 Views)
This 100%. Once it burns you for the third or fourth time, you'll barely ever use it again.
Redhawk
Message 16 of 18
(1,211 Views)
Or Ctrl-L
I'm mouse-oriented.  😉
Bill
CLD
(Mid-Level minion.)
Message 17 of 18
(1,190 Views)
I'll second, third and fourth this opinion!
Bill
CLD
(Mid-Level minion.)
Message 18 of 18
(1,188 Views)
