Block Memory and Read Latency outside SCTL
I have a simple question about LabVIEW FPGA which I believe is causing me trouble:
If I am reading a block memory outside of a SCTL (in a normal while loop) and the block memory has 2 cycles of read latency, will the block memory provide a proper value in a given iteration without any pipelining or other considerations?
Thank you
(1,683 Views)
Thank you
I have only used it in a SCTL.  I think this could be tried out in a simple test VI.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,635 Views)
Accepted by topic author Gryffin
I've only ever used SCTLs, but I think normal while loops handle all of the latencies in the background, so yes I think it should return a valid value each time. But this needs to be tested in a VI.
(1,619 Views)
