Block cell size in a table
Hi everyone. When i tried to fill/edit a cell in a labview table i'm having the next issue:
Someone knows how to block cell size in this table? May am I missing some property?
I will appreciatte so much. Thank you.
(945 Views)
Are you pasting line feed characters? You can try to disable Autosize Row Height.
(907 Views)
We cannot troubleshoot your problem by starting at images.
What is your definition of fill/edit (typing characters? Pasting the collective works of Shakespeare from the clipboard? How is the input validated?)
A table is typically much more useful as indicator, not as control. Can you attach a simplified version of your code with typical default data in the table, then explain what you are doing.
(895 Views)
