11-14-2012 04:19 PM - edited 11-14-2012 04:37 PM
Thanks RavensFan. So I would wire the front panel button to the top input connector. But what would I wire to the other input connector?
11-14-2012 04:36 PM - edited 11-14-2012 04:37 PM
Aalenox,
Actually, I do have other stuff in the main VI, although I could easily incorporate your approach into what I have now. Ideally, I'd like to use a subVI if only because I think it would be useful for future projects.
Thank you, though, for taking the time to put together that example. I didn't know you could combine references into an array like that.
11-14-2012 04:40 PM
As a general rule, if something has a wire out - you can toss it in to an array 🙂
11-14-2012 04:42 PM
RavensFan,
Oh, I think I get it. The two inputs are the button itself and a reference to the button. Is that correct?
11-14-2012 04:46 PM
11-14-2012 06:15 PM
@dan.laks wrote:
RavensFan,
Yes. The reference on the button so that the subVI knows what control to work with for the property nodes. I also set it to wire up the boolean directly to pass in the value. Your VI had a value property node, which could have worked, but because of the latching action of the boolean, the data type for value was variant rather than a boolean. So I figured it would be easier to just pass in the value rather than dealing with a conversion of the variant data type.
11-14-2012 06:22 PM
Ah, I was wondering about the variant data type. I didn't think it had to do with the type of button (latching vs non-latching). Thanks for the explanation.
