Block diagram hidden
I have started working on  labview after a long gap on same program.but now i am facing some problem with block diagram.
i could not swicth from my front panel to block diagram. since i am working on the same system i could not trace out the problem.
i am attaching a sample vi where i can edit  the front panel but not the block diagram.
i can see the option for changing to block diagram in front panel.but it doesn't work
i am using Labview 7.1
Praky
(3,020 Views)
I get this error...!
with Labview 8.5 and 8.6
Try rename it and "save as". Maybe for previous version...
Message Edited by Pnt on 01-29-2009 12:51 PM
(3,017 Views)
You saved this VI with the option 'Remove Block Diagram'. There is no way without the original VI to get to the code of the VI.
Ton
My LabVIEW Ideas
(3,013 Views)
