Block diagram not saving
I installed LabVIEW 3 hours ago or so and I just finished up a homework assignment for one of my classes. I saved the VI, and opened it just to make sure it worked, but the block diagram did not save. The front panel came up fine with everything I put on it, but the block diagram does not pop up at all. What is the problem?
Message 1 of 9
(5,052 Views)
Hello Paulhs94,
You can access the block diagram via the CTRL+E hotkey or via Window>>Show Block diagram.
Tom L.
Message 2 of 9
(5,044 Views)
Is it possible that it is off screen? I have seen both front panels and block diagrams which have been moved so that only one pixel is in a corner of the screen, making it almost impossible to see. Usually this happens on when the VI is opened on a system with a smaller screen than the one on which the VI was developed.
Try going to the Window menu and select Tile Left and Right.
Lynn
Message 3 of 9
(5,040 Views)
Unless you somehow managed to activate the property Remove block diagram, but i think that's only applicable for source distributions.
/ Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 9
(5,039 Views)
Somehow saved it without the block diagram?  It is a setting when you create a source distribution.  But it would be very difficult to do accidentally.
Message 5 of 9
(5,034 Views)
Is development PC and current PC are same?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 6 of 9
(5,032 Views)
To elaborate on my previous statement- When you create a new VI, both the block diagram and front panel will open automatically.  When an existing VI is opened, only the front panel will be displayed until you open the block diagram manually.  This is certainly easy to miss the first time you use the environment.  As others have mentioned, saving a VI without a block diagram is possible but seems unlikely in this circumstance
Tom L.
Message 7 of 9
(5,020 Views)
May be I am wrong but when I also open the existing VI only FP opens. Keep deleting the BD at last option and keep the backup.
--Ranjeet
Message 8 of 9
(5,010 Views)
What does this message even mean?
Message 9 of 9
(4,978 Views)
