Blown Up/Shrunk Boolean Indicators on the partially viewable front panel
My VI works fine on my laptop but after the executable is built and deployed onto the target device(WindowsXP), I could only view part of the front panel and one Boolean indicator and Progress Bar show up in either very big or very tiny sizes.
The application is a monitoring device that runs ten while loops in parallel and communicate via notifiers.
The hardware is USB-6008 and currently uses 3 Analog Inputs and 5 Digital Outputs(3 of which connect to silicon relays and 2 unwired).
Can anyone shed some light on this issue?
(2,902 Views)
Can you show us a screenshot?
Is it possible that the screen resolutions are very different and you have things set to scale with the panel.
  1. What are your settings in VI properties..windows size and ...Window run-time position?
  2. RIght-click on the FP objects that look odd. What are settings such as "scale with panel" and "fit to pane"?
(2,903 Views)
Window size was 570 by 411.  Run-Time position was Unchanged.
Scale Object with Pane was checked.  Is this right?
Thanks.
(2,891 Views)
Don't set any objects to scale with pane and see if things improve. 🙂
(2,877 Views)
I set all objects to scale with pane and things just worked wonderfully!
Thanks so much for your help.
hellolv
(2,874 Views)
