12-09-2005 04:02 PM
12-09-2005 07:39 PM
Are you fairly sure that your XP install has the latest MS fixes, patches, etc??
Does your system meet the installation criteria for LV 8?
12-12-2005 08:42 AM
I installed all of the latest MS patches/fixes before installing LabVIEW.
My system exceeds the requirements for LabVIEW 8.
Now that I have returned to the "last working config" that rolled back the registry/driver updates from LabVIEW, LabVIEW works except that I still get the nidevmon.exe error every time I boot the system.
12-12-2005 06:01 PM
03-12-2006 12:26 PM
03-13-2006 04:47 PM
Have you tried disabling the NI Device Monitor so that it does not run at startup? Please right-click on the icon in your taskbar and then choose "Run at startup" so that it does not have a check mark next to it. This will disable the NI Device Monitor from running at startup.
To isolate the blue screen issue, I would recommend uninstalling all of the drivers to see if you get the blue screen with only LabVIEW installed. To do this, uninstall Measurement and Automation Explorer (MAX) and all of the drivers will uninstall as well because they are dependent on MAX. Then, check if the blue screen still occurs.
Post back the results,
Laura
03-13-2006 06:46 PM
03-14-2006 03:44 PM
Hello Arash and Cl.Consulting,
Are either of you using McAfee virus scan?
Also, Arash, the fact that you have reinstalled the driver to no avail may be indicative of a larger software problem. I recommend that you contact support. You can do so at ni.com/contact.
Laura
03-14-2006 04:28 PM
03-14-2006 04:36 PM
I had a similar issue when I installed Labview 8 over Labview 7. My blue screen said "Bad Pool Caller".
This event occured on two computers, but I have not had time to debug why. Just wanted to throw it out there.
Clean format and Labview 8 fresh install fixed all.
Joe
