03-20-2006 02:47 AM
Dear Laura,
i'm experiensing the same problem: nidevmon give me the error starting, but i cannot disable it: there is no icon on taskbar, maybe because it doesn't start correctly
What can i do to disable it? Thankyou
03-20-2006 04:16 PM
Hello PincoG,
Before we try to disable the Device Monitor I would recommend reinstalling the driver. First, uninstall NI-DAQmx using Add or Remove programs (it will be part of the NI Software entry) and then download NI-DAQmx 8.0.1 from our website and install that. Please let me know if it fixes the problem.
Laura
03-23-2006 09:50 AM
Hello PincoG, Arash, and Cl.Consulting,
Can one of you post a screenshot of the error you are getting about the device monitor initializing? Also, after you get this error, are you still able to use whatever hardware you have installed? Can you run test panels on it in MAX?
Your response is appreciated in helping us track this error.
Laura
03-23-2006 10:08 AM
03-23-2006 10:51 AM
03-24-2006 05:39 AM
03-24-2006 01:38 PM
Hi Arash,
Did you email in to technical support? If not, could you please do so? When you do, please put my name in the email so that they know I asked you to email in.
Thanks!
Laura
03-24-2006 01:38 PM
Hello Christian,
Thank you for the information - I am glad to hear everything is working correctly!
Laura
03-27-2006 02:01 AM
I'm updating ten pc working with the same program. Ido not have to install labview 8 on each system because the they works witha compiled application.
Since the application seem to work correctly, and i don't need the NIDev monitor, is there a way to disable it? (Also when it doesn't start correctly?)
Thanks a lot.
03-27-2006 11:09 AM
Hello PincoG,
Have you installed NI-DAQmx on these other computers and seen this problem? If you are not seeing this problem initializing the device monitor and you can see the icon in your task bar, you can right-click on it and choose "run at startup" so that it does not load at startup. If you do not see the icon and are getting the initialization error, please go to ni.com/support and choose to email technical support. Reference me and the problem that you are having in the email.
Laura
