Bluetooth Conncetion
I am doing a project and need to use bluetooth panel.... however i have connected my bluetooth device to Computer and i have proper Bluetooth Drivers (BlueSoiel). My vista is running without any problems using Bluetooth. However when i open NI and search for Devices, it's showing up 0... What should i do inorder to use Bluetooth..
When i try to use Bluetooth Connect, it's giving Error 58 and NEtwork TCP/IP error..
*searched forums and didn't find working solution to my problem...
(3,228 Views)
You need to enusre that your Bluetooth radio uses the Microsoft drivers, LabVIEW is not compatible with other vendor's BT drivers.
http://digital.ni.com/public.nsf/allkb/B4C0FCC67BF4485486256F12005B6D61?OpenDocument
(3,188 Views)
