Bluetooth client server VIs
Hii all,
I am developing bluetooth application using labview bluetooth vis.
 I have my bluetooth enabled PC using bluetooth dongle. Now I want to send some data, say a string Hello from my PC to a Nokia mobile 2700 series. Is it possible?
If Yes , in such case
1) What will be my client and what will be the server? as I intend to use client/server VIs provided in labview example finder . What is the exact difference between client and server in bluetooth domain?
2) Can I run both the VIs on same PC?
3) Simple Client VI uses "Bluetooth Open connection" VI ...so which address do I need to provide there ..is it PC's bluetooth address or Nokia's bluetooth address?
4) Simple Server VI uses "Create Listener" VI who asks for UUID...which UUID needs to be provided..is it PC's or Mobile's bluetooth?
Please do the needful.
Best Regards
Message 1 of 1
(2,509 Views)
