Bluetooth example in labview 8.6 doesn't work
I am using the bluetooth client/server example with labview 8.6. The severer reads my bluetooth adress but the client won't connect (error 59) , the adress and channel i typed into the client are correct, i am using vista and don't know if this is the issue.
Any ideas cheers?
(3,754 Views)
The build in support that LabVIEW has for Bluetooth only supports the native Microsoft Bluetooth and a limited set of hardware. For example, if you have a dell preloaded with the Toshiba drivers for Bluetooth, LabVIEW will not detect your hardware and have similar issues to what you are having.
Amit
(3,717 Views)
Hello Zac,
I hope you are doing fine. Could  you please specify what hardware are you using? Basically error 59 means that the network is down, unreachable, or has been reset.
Please have a look at the following forum post as well
http://forums.ni.com/ni/board/message?board.id=170&message.id=255170&requireLogin=False
http://ae.natinst.com/operations/ae/public.nsf/webPreview/8295C04C0A038E8686257500005CCA99?OpenDocum...
Fawad Nisar
National Instruments UK & Ireland
(3,692 Views)
