Bluetooth problem
Hello all,
I have a problem working with EDIMAX Bluetooth dongle.
i tried to use labview Bluetooth vi "Bluetooth Discover" i did not get any error but it doesn't work(it doesn't discover any peripherial).
i used other program and it discover the peripherial.
while running dependencies walker on the other program i got that it use TOSAVAPI.DLL
waiting for your advise how to solve this problem i want to use Bluetooth in labview.
thanks
Nadav
(3,381 Views)
Dear Nadav:
  There very well could be a compatibility issue.
Did you try a different kind of usb dongle if you have one?
Did you try one of our example VIs as shown in the attachment. It is hard when you dont have an error code or any warning.
Did you try our example programs (simple bluetooth client.vi) do not work and give you the same issue. Can you give the address directly of the bluetooth device instead of the discover VI and observe what happens?
I have posted some links that have had issues with bluetooth dongles in the past for you to try out.
http://forums.ni.com/ni/board/message?board.id=170&message.id=153515&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=87261&requireLogin=False   (Post from Michinga might be useful)
Thanks and hope this helps
looking forward to a reply
Avi Harjani
(3,357 Views)
