Bomb-proofing VISA serial interface
Hi
I am running labview 11.0.1f2 (32 bit) on a windows 7 PC, talking to a KMtronic USB relay device.I have problems when I am trying to communicate with Labview.
I have attached a snapshot of the program and the error.
Grateful if you could help. Thanks.
Bhimsen
Message 11 of 17
(1,140 Views)
Hi bhimsen,
- which COM-Port are you trying to use?
- does your hardware even provide a COM port?
Message 12 of 17
(1,128 Views)
I don't have my development machine available today but will chack against my code as soon as I am able. Can you post a picture of the front panel so we can see the final string been written and COM port?
Mark.
P.S. GerdW, a functional KMtronic relay does provide a COM port (it runs a USB-Serial adaptor then the relay accepts instructions written to the "virtual" serial port)
Message 13 of 17
(1,117 Views)
I have posted the picture of the front panel.The relay board does have USB port. I have tested it with its driver, it's working perfectly.
It is working in Labview in the single run mode. However, it is showing the error while on the 'run continuously' mode.
Thanks for your help.
Bhimsen
Message 14 of 17
(1,108 Views)
Hi bhimsen,
never use "Run Continuously" except for debugging purposes!
- Use a while loop when you need your VI to run for some (unknown) period of time!
- Don't initialize the port in each iteration!
- Don't close the port in each iteration!
- Use some decent wait instead of banging the hardware as fast as you can!
- Go through some LabVIEW basics!
- Look at the supplied example VIs! I recommend "Advanced serial read and write" example VI...
Message 15 of 17
(1,103 Views)
Thanks for your advice. I'll try and let you know.
Bhimsen
Message 16 of 17
(1,094 Views)
Hi
It's working now.
Thank you for your help.
Bhimsen
Message 17 of 17
(1,033 Views)
