Bookmarks are deleted while generating MS word report from template.
Edited:
@aputman: I tried restricting the doc/template editing to form fill only but no help... 😞
That's strange, I tried it and it worked fine.
Ben64
Message 11 of 23
(2,266 Views)
If I run this code, it works without error.  Not sure what your issue is now.
aputman
Message 12 of 23
(2,261 Views)
PLease follow following steps:
a. Run the code. Create and save a file (with data populated in the file).
b. now modifiy the code to open the file you just created (and not the template) and now run the code.
The intent of second step is, open an already created file and change/overwrite the data in it. However this time you'll see an error (-41110).
Message 13 of 23
(2,258 Views)
James code works well, it does the same thing as specified here.
Ben64
Message 14 of 23
(2,242 Views)
I'm pretty sure my idea is what OP wants. Here, I edited his code to just the basic bookmark insertion code and it runs as I believe he wants.
Edit: Thanks ben64
Cheers
Message 15 of 23
(2,237 Views)
Another (better....maybe) solution would be to not have text as part of the bookmark.  If you highlight text and Insert -> Bookmark, the text becomes the bookmark and is deleted when text is appended at this location.  If you place the cursor at a location and insert the bookmark (with no text selected), it doesn't disappear when the text is appended via Labview code.  This doesn't require any additional code to reinsert the bookmark.
aputman
Message 16 of 23
(2,229 Views)
Sorry James.  I read the OP's explanation that fields were being used and I assumed they were talking about form fields.
aputman
Message 17 of 23
(2,228 Views)
One disadvantage of using a bookmark as a single point instead of a range, is you would need to figure out what text is next to the bookmark in order to replace that text with a different value. Otherwise, you would have every value just appending with the previous values each time.
Cheers
Message 18 of 23
(2,222 Views)
Good point.  Form fields to the rescue.  (or just do what James did Smiley Wink)
aputman
Message 19 of 23
(2,211 Views)
Thank you all so much.
I hope, I'll be able to use James code... I'll try it tomorrow...
Requesting James to save the code in version 2013...
Message 20 of 23
(2,210 Views)
