Boolean LED Blinking in Array of Cluster
I did not found anything to my problem in the developer zone of ni.com. Only how to index a element in an array of cluster.
I want to set the Property "Blinking" of a boolean LED control in an array of cluster. But all attemps were to no avail and nothing happens.
Can someone look at my VI please?
Thanks shavo
Message Edited by shavo on 05-28-2009 05:12 AM
(3,634 Views)
It's not possible to change the physical property of the element of a array of cluster.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,628 Views)
