Boolean Logic Problem
Hi All,
Looking for help with a logic problem, not sure if this is the right area for it.  Basically I have a single input that needs to control two outputs.
For example, if input is a one, I need output #1 to be a one and output number two to be a zero.  If the input is a zero, I need output #1 to be a zero and output #2 to be a one.
Can this be done??  I have tried a number of different gate combinations but can't seem to get it.
Any help much appreciated.
Trent
(3,858 Views)
It sounds like output #1 is equal to the input.
And output #2 is NOT the input.
(3,856 Views)
You mean you didn't try something like this?
(3,849 Views)
Logically, this thread would belong in the LabVIEW forum 😄
(3,839 Views)
Unless he is doing it in another language, say CVI  Smiley Wink
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,793 Views)
True, it might even be a electronic circuit design question.
So, he might want to use an inverter for the second output. 😄
(3,787 Views)
