Boolean Logic
It's not so much of a LabVIEW issue... more of a logic issue, it's late in the day and my mind is mush at this stage. Here's my desired functionality;
I read two controls in a loop labeled: Boolean and Boolean 2 respectively. Boolean is initialized to true.
If Boolean 2 is pushed, then Boolean should go false and Boolean 2 should go true.
Likewise if Boolean is pushed, then Boolean 2 should go false and Boolean should go true.
There should never be a case where the two buttons are both false or both true.
I've tried many combinations of boolean logic both in labVIEW and on paper but can't come up with a solution as of yet and am looking for a pointer.
VI attached and I apologise for the unimaginative control names.
Strokes
(3,593 Views)
You could use radio buttons.
This isn't really a boolean logic question, just a user interface question.
What you need to do is use local variables or property nodes to set the other boolean.  Better yet would be to use an event structure.
(3,585 Views)
Hi strokes,
ever tried those funny items named "radio buttons"? 😄
(3,582 Views)
AHHHHHHHHHHHHHHHHHHHHHHHH radio buttons. I knew I learned about them for some reason in college...
Anyway I can get rid of the border around them in the Modern control/indicator palatte? I've tried translucent brush. I think it may only be possible to get rid of a border when choosing from the Classic panel if I remember correctly but not sure...
(3,570 Views)
Correct.  Transparent brush on the radio button container from the classic palette.
(3,567 Views)
Correct2: Transparent brush on the radio button container from the modern palette. Remember to set both colors (FG/BG) to transparent...
(3,561 Views)
