Boolean Switch Auto On/ Off with respect to a case structure
Hi all,
 I have attached My VI. The  Boolean switch has enter into   True and  false  case structure automatically. How can I connect the Boolean switch to make it happen please.
(1,271 Views)
@RRBB wrote:
Hi all,
Not able able to open the attached VI ( Not all Forum users will be using the latest versions its better to share the lower version)
Based on your statement, I guess using shift register will solve your problem.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,207 Views)
Not sure what you are trying to implement here.
Note that the Boolean control is only read once since it is placed before the loops.
https://tmesystems.net/
(1,191 Views)
yes that's right. when I  don't click the boolean button the false statement runs. when I click on Boolean button true statement runs. THis functions happens only manually. I want to make it auto.
(1,154 Views)
Accepted by topic author RRBB
used a FOR loop for boolean button with not logic. solved. Thanks
(1,141 Views)
