Boolean Text of Multiple Buttons
Is there an easier way to read several Boolean Texts? Possibly through a for loop but would need to be able to change the reference to accomplish this task.
19591i8234A81986269A3A
CLD Certified 2014
(3,375 Views)
Build the 4 boolean references into an array.  Feed that array into a For Loop with autoindexing.  Inside that is the property node.  The string output of the property node will exit the For Loop with Auto-indexing turning it back into a string array.
(3,369 Views)
To be completely honest... I figured it out. I did the same thing you just suggested. I just was stumped for a while. I posted this in frustration. Thank you for your effort.
CLD Certified 2014
(3,365 Views)
Accepted by topic author ADrexelDragon
It almost looks like all your buttons are in one cluster, so you could do something like this instead.
(If the cluster also contains other controls, a little it more code is needed).
(3,347 Views)
