Boolean and array can't be populated outside of timed loop.
Thanks guys. I think for now I will just keep the save function inside the loop for simplicity and only execute it every 1000 iterations. Channel wires might have worked as well.
Message 11 of 12
(199 Views)
You could also have a look at the Producer/Consumer, which uses a queue instead of a channel wire.
Message 12 of 12
(185 Views)
