Boolean array
Hi All!
I have boolean array. I need to chek if more than one element of array is true, if so it's faul state. How can i do it?
Message 1 of 9
(4,846 Views)
Hi john7,
see the "boolean array to number" function and check the result.
Mike
Message 2 of 9
(4,837 Views)
Hi  MikeS81! If i use boolean array to number wich number indicates two bits set high? I should go and scan all cases. It's not so elegant especially if array is varying in size.
Message 3 of 9
(4,834 Views)
Use "boolean to 0,1" (it also works for boolean arrays) followed by "add array elements". If the resulting sum is >1, you have a fault.
Message 4 of 9
(4,827 Views)
Check the attached vi. I have used a conditional for loop. (not sure if it is the best solution)
Nitz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved;))
Message 5 of 9
(4,822 Views)
sorry for the confusion. Altenbach is absolutly right.
Mike
Message 6 of 9
(4,821 Views)
Hi John,
use Boolean to 0/1 and a ArraySum function...
Oops, shouldn't look at other websites in the mean time Smiley Wink
Message 7 of 9
(4,818 Views)
Thank you guys! Absolutelly perfect! Smiley Happy
Message 8 of 9
(4,811 Views)
Also, if you expect the possibility that the boolean array is larger that 2^15 (32k), you need to convert the output of boolean to 0,1 to I32 before taking the sum.
Message 9 of 9
(4,805 Views)
