Boolean button
Hello, it´s me again.
I have a new question: Is there a way to create a boolean button which when
it is pressed immedeatley goes back to the default value ( e.g.
TRUE-->FALSE-->TRUE)?
I mean, when you click the button you should have FALSE just that one
reading (this function is to be implemented in a while-loop).
Thak you again!
/Peter Jansson,
Teracom Systemservice Malmoe Sweden
http://www.teracom.se
(3,296 Views)
Pop-up on the button and go to 'mechanical action'.
You can use 'latch when pressed', or more accurate for just one
reading: 'latch when released'.
Hope this helps!
Erwin.
(3,296 Views)
In article <963389852.705397@proxy2>, peterjan@teracom.se (Peter Jansson,
> when
> Thak you again!
> /Peter Jansson,
If you select the mechanical action to be latch when released, when the
boolean is read it will return to its default.
Try looking at the mechanical action of booleans example to see how the
different mechanical actions alter the way the switc
h functions.
Cheers
Bill
wsymonds@clara.co.uk
(3,296 Views)
