Boolean functions accepts numeric values..
I recently came to know that all Boolean functions accept numeric values as well. But what is the purpose of it?
I found the Boolean functions outputting some random values while inputting numeric values..
Thank you!!
Best Regards,
Rashme SR
Message 1 of 8
(5,444 Views)
The definition of a bool is x != 0, so that's what the function should equate to.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(5,434 Views)
Hi Rashme,
The purpose is to apply boolean functions to integer values.
Instead of scalar booleans you can put 8/16/32/64 bits in an integer value and you can apply a boolean function to the whole integer (and all it's bits) at once.
Quite handy once you learn such stuff (when programming µCs at the assembler level)!
Message 3 of 8
(5,427 Views)
Ah, i misunderstood. Gerd is spot on. If, e.g. you want to know if the 4th bit is set, you can AND with 8 and compare to 0. If 0 it wasn't set, else it was. Now how is that beneficial? Many protocols just bits as flags, e.g. Intermec uses a 32 bit integer to set all relays in a module and thus you need to filter and set bits with AND and OR to do it efficiently.
/Y
Qestit Systems
Message 4 of 8
(5,416 Views)
Another common use case is x AND 1 to see if a number is even/odd.
/Y
Qestit Systems
Message 5 of 8
(5,407 Views)
I dont understand clearly. Can you please attach an example?
Message 6 of 8
(5,401 Views)
Accepted by topic author Rashme_SR
What do you not understand?
When boolean logic is used on integers, the logic is done on a per bit basis.  I do this all the time for encoding and decoding data from specific protocols (some more wild than others).  This is also needed for many data checks (like a CRC or Reed Solomon) and for encryption (AES, DES, 3DES).
Message 7 of 8
(5,382 Views)
Thank you so much.. finally i understood.. Doing binary calculations using numeric controls.. Its awesome
Rashme SR
Message 8 of 8
(5,364 Views)
