Boolean ones count and then switch on even sum
I am trying to switch a load with a trigger button of a joystick which basically gives a boolean output. I want to switch on alternative taps on the trigger button. I have written code to check even and odd sums but could not make part that actually sum '1' of boolean input. Switch should remain ON until next tap (zero to one OR one to zero shift). Any help?
(1,091 Views)
If you've "written code", attach it so we all have a chance to fix it.
(1,072 Views)
See if this can give you some ideas:
(1,034 Views)
Depending on how the external switch works, maybe a little more code is needed. See here.
(1,030 Views)
