Boolean properties window cosmetic glitch
When selecting "Properties"in the contextual menu of a Boolean control, the following window opens:
Notice the location of the "Show Boolean Text" checkbox.
It might be intended, but I doubt so.
Message 1 of 14
(5,599 Views)
I wager intended on this one.
Message 2 of 14
(5,577 Views)
I think it is where it was intended to be but the label background should not be transparent.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 3 of 14
(5,564 Views)
I feel so 20th century, esthetically speaking, reading these comments...
Message 4 of 14
(5,554 Views)
Do not confuse 'intended' with 'desired' or even 'standard'.  On my phone it was hard to see the group box line extending beneath the label.  But yes, it seems the intention was to create a set of dependent controls with the Checkbox.
It would be standard behavior if the caption text box was always enabled and entering text would automagically click the visible box.  Same for the label.
I do not think it is necessary for the visible check box to disable the other controls.
Message 5 of 14
(5,535 Views)
It looks a bit different to me on my Win7 computer.
I do believe the checkbox is supposed to be over the line since it is a header for that group box.  I don't think you are supposed to see the line through the text.  On my Win7 PC, the line doesn't show up behind the text.  What I do find weird is that the checkbox text looks bolder than it should, and looks bolder than it looks on yours.
I'll have to look at this on my XP machine when I get a chance.
Message 6 of 14
(5,526 Views)
Question, which control palette is the control in the original post from? Classic? Modern? Silver?
Kelly Bersch
Message 7 of 14
(5,518 Views)
Silver, but that occurs for all styles.
Message 8 of 14
(5,468 Views)
What version of LabVIEW are you using?
Here is my property dialog for a silver boolean withing LV 2012 (the Win7 image earlier was also LV12).  I don't see the line behind the text.
Okay.  I'd attach the .png file that shows this, but the forums are giving me the "The contents of the attachment doesn't match its file type" error.  I haven't seen this one in a long time.
Message 9 of 14
(5,462 Views)
LabVIEW 13.0f2 (32-bit)
Message 10 of 14
(5,453 Views)
