Boolean text.Size to text , the boolean text size fixed in my Custom button
@paul_a_cardinale wrote:
This is very risky.  The bit meanings of Basic Object Flags can, and sometimes do, change between versions of LabVIEW.
No Risk — no Fun. Any official alternative?
Message 11 of 19
(1,550 Views)
There is an INI key that helps with these boolean operations.
enableSecretPopups=True
Christina talks about it a bit here on LAVA.  After enabling it when you go to customize a boolean you'll have a bunch of new popups for things like centering text, or having the boolean decal grow with the button resize.  This one is particularly useful for vector based images like WMF.
It is an undocumented and unsupported INI file so it is possible you can create a boolean that crashes LabVIEW, or does weird stuff, so tread lightly.
Message 12 of 19
(1,543 Views)
Yes, that was my initial idea, but in this particular case the options looks exactly the same for both "original" and "modified" controls, so I wasn't able to revert "Size to Text" back with this (played only a little bit):
On the other hand, this is undocumented, you're right, may be some additional menu or option exists, who knows.
Message 13 of 19
(1,534 Views)
@Andrey_Dmitriev wrote:
Unfortunately this will help only partially, because "Size to Text" will remain inactive, in aditional, this will cause overlap with icon if Boolean Text should be not centered absolutely:
You can define your own "center" in Customize Mode by move an already centered Boolean Text to a new position.
The LockBoolText property node will not move the Boolean Text back to the original center.
George Zou
Message 14 of 19
(1,510 Views)
This is true, you're perfectly right, but this will not help to "grow" the string in attempt to put longer text like it growing when Size to Text Option set (like Labels/Captions) for example. As result I should not only move it, but also resize to maximal possible length, which is quite inconvenient, especially for localized application, where length may vary. I have had already "trimmed" text in rare cases where Boolean text was touched occasionally.
Message 15 of 19
(1,507 Views)
Define a new center is just for avoiding Boolean Text overlap with the icon.
George Zou
Message 16 of 19
(1,501 Views)
The attached is much less risky.
Message 17 of 19
(1,486 Views)
For instance, on LV 2021 BOF returns 60000 hex regardless of whether STT is True or False.
My mistake.  It's still the same in LV 2021.
Message 18 of 19
(1,481 Views)
Message 19 of 19
(1,443 Views)
