Boolean true/false for String Control
Hi All,
Is there a simple way to determine if there are any characters populated into a string control?  For example, I would like to produce a boolean true if there are characters written in the string control, and false if the control is empty?
Nick
(2,472 Views)
Accepted by topic author NickIke1
Try negating the output of "Empty String Path Filename?" on the Comparison pallet.
(2,467 Views)
Perfect, thanks!
(2,459 Views)
Also remember that string controls have a few more additional useful options such as "limit to single line" and "update value while typing".
By default, characters in a string control are not read by the code until the entry is finalized (clicking outside, hitting <enter> if set to "limit to single line", etc.).
If you set it to "update value while typing", you'll get a more instant response if programmed correctly.
(2,385 Views)
